8 years agoWhy is my inout signal converted to output by eda netlist writer?
My simple test dut consists of the following code. When I run a compile on this code (Processing ->start Compilation) the netlist written by the EDA Netlist Writer has signal defined as output inste...
8 years agoReceived a message from Intel confirming that they were able to reproduce the bug and have assigned it to the dev team.
Waiting for the workaround/fix.
