8 years agoWhy is my inout signal converted to output by eda netlist writer?
My simple test dut consists of the following code. When I run a compile on this code (Processing ->start Compilation) the netlist written by the EDA Netlist Writer has signal defined as output inste...
8 years agoThe recommendation is to not have the conditional on the incoming signal. Just get rid of "if (dir)" in the always block.
