8 years agoWhy is my inout signal converted to output by eda netlist writer?
My simple test dut consists of the following code. When I run a compile on this code (Processing ->start Compilation) the netlist written by the EDA Netlist Writer has signal defined as output inste...
8 years agoI did compile both the projects in the zip file that you sent. Both have same results for me. I get BiDir ports in both and on multiple runs . No change in implementation.
