8 years agoWhy is my inout signal converted to output by eda netlist writer?
My simple test dut consists of the following code. When I run a compile on this code (Processing ->start Compilation) the netlist written by the EDA Netlist Writer has signal defined as output inste...
8 years agoThe zip file was created using tool version 17.0, I will recheck with 17.1
In case it matters, my system is %uname -a Linux Dyumnin 4.13.0-16-generic# 19-Ubuntu SMP Wed Oct 11 18:35:14 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux For the Altera example code, I did not change any settings. My Process was as follows. mkdir output cp bidirec.v output cd output {Launch Quartus} {Do File->New->New Quartus Prime Project} {select the device, project folder and verilog file} {Do Processing->StartCompilation} {Check netlist writer has generated inout port: YES} {Do Processing->StartCompilation} {Check netlist writer has generated inout port: NO}
