Why is lpm_add_sub greyed out in the IP library for Max 10 devices?
The lpm_add_sub does not greyed out in the Intel Quartus Prime Lite v19.1
Did you install all the devices during the software installation?
KhaiY
- JGood256 years ago
Hi, I installed all devices. Then I right-clicked in the .bdf window, selected "insert symbol", and got following dialog:
Then I looked in the IP catalog:
I had previously imported an instance of lpm_add_sub from an earlier project made under quartus prime 15.1:
When I double-clicked this symbol, I got the wizard dialog:
The device assignment is 10M08SAU169C8G, although I have tried with several different MAX 10 devices, always with the same result. When I try the same with a Cyclone 10 device, the lpm_add_sub reappears:
I have a workaround (by importing an instance of lpm_add_sub as project ip) but it would be great if I could use it directly.
Joe
Hmmm...my graphics disappeared when I sent. Here they are:
- insert symbol dialog:
- IP library dialog:
- add_sub instance from .bdf:
- MegaWizard dialog:
- insert symbol dialog with Cyclone 10 device assignment:
