IElha
7 years agoWhy I cannot edit the GPIO Lite Intel FPGA IP in Quartus 18.1?
this is the log error message i got when tried to edit the gpio lite intel fpga using quartus 18.1 and MAX 10 device
Megafunction GPIO Lite Intel FPGA IP v18.1 is not listed in any
wizard.lst file in the specified library path(s).Wizard launch aborted
- SreekumarR_G_Intel
Hello , Is the log file attached ? Sorry I couldn't find , Can you copy and paste in the forum ? Thank you , Regards, Sree - IElha
Hi All,
I put it here in case someone will face the same issue.
You should add the next line "<ALIAS>GPIO Lite Intel FPGA IP v18.1</ALIAS>"
to altera_gpio_lite_wizard.lst file.
This file is located at \\intelFPGA\18.1\ip\altera\altera_gpio_lite\
Thank you , Can you please close the case ? Regards, Sree - SreekumarR_G_Intel
Hello , here is the link to get more detailed about the issue and fix https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2018/failed-to-launch-megawizard-plug-in-manager--pll-intel-fpga-ip-v.html Hope helps , Thank you , Regards, Sree
