oAng0
7 years agoWhy fitter incremental compile and single compile yield different timing result
I realized the timing result is different if I compile a Stratix 10 design using incremental compile versus single compile. By incremental compile, I mean I compile the design stage by stage during ...
oAng0
7 years agoAs stated in my first post, the only different is the flow of compilation ( single vs incremental ) . Are you saying Quartus use different number of processors to compile between these two flows?
