oAng0
7 years agoWhy fitter incremental compile and single compile yield different timing result
I realized the timing result is different if I compile a Stratix 10 design using incremental compile versus single compile. By incremental compile, I mean I compile the design stage by stage during ...
GuaBin_N_Intel
Contributor
7 years agoLooking at this document https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-compiler.pdf, 1.7.3 Factors Affecting Compilation Results. It gives some factors that can impact the compilation result. Seems that number of processors running the design may give different result.
