oAng0
7 years agoWhy fitter incremental compile and single compile yield different timing result
I realized the timing result is different if I compile a Stratix 10 design using incremental compile versus single compile. By incremental compile, I mean I compile the design stage by stage during ...
GuaBin_N_Intel
Contributor
7 years agoI'm not aware of any compilation difference between these two different flows. It seems that the script is working same for both of the flows. After tried to restore design and do incremental compile twice, it produces the same results. See if I could find out what flow difference is.
- oAng07 years ago
Hi GNg,
Thanks for looking into this. Do you mean you aren't able to reproduce the timing results differences between single_compile and incremental_compile using the attached design ?
