JSone
7 years agoWhy evaluation time expires for Quartus Lite Edition
If I compile using Quartus Lite Edition, I have a error as follows: ---- Error (210039): File C:/Users/.../DE10_NANO_SoC_GHRD_time_limited.sof contains one or more time-limited megafunctions that...
sstrell
7 years agoAs mentioned, you have some IP in your design that requires licensing. The Lite edition is free to use, but if you create a design with IP, you either get time-limited .sof files, as mentioned, or you need to get licenses for the IP to remove the limitation.
