8 years agoWhy does the same path have different timing in TimeQuest?
Hello! I'm trying to constraint a source-synchronous output on my FPGA but I'm getting some timing numbers I can't quite understand (I feel they should be different). I've read Rysc's pdfs on bo...
8 years agoThat makes sense, now that you mention it I remember you wrote about it in your TimeQuest guide (about common clock path pessimism). I just hadn't yet fully understood this was what you meant.
The ccpp removal is in the left screenshot, line 35, I just didn't include that column because I thought what I was seeing had something to do with the path and on all the other lines it just included net names so I figured it wasn't relevant. Thank you for your time! =)
