Bosenraum
8 years agoWhy does Qsys stop responding when generating DDR3 external memory interface?
I am trying to generate a design that is using the DDR3 SDRAM Controller with UniPHY IP core and during the Qsys HDL generation the generate window will hang rendering Qsys unusable. I am using Quart...
LinuxFanatic2018
8 years agoDid you tried some examples for other FPGA and development boards? May be this problem caused by wrong settings? And other demo projects will generate/regenerate flawlessly?
