11 years ago*Why* does analysis fail (err 17044) for some qsys + ddr projects?
Dear all, tl;dr: Error (17044) - how to stop those from happening when starting a qsys/nios/ddr3 design from scratch where the qsys part is NOT the top-level entry. I have successfully ...
11 years ago --- Quote Start --- *What* makes the ddr 3 controller so special that it requires the qsys to be the top level design component? --- Quote End --- This is not correct. I never use Qsys as the top-level module. --- Quote Start --- I like to work from a blank slate, adding what I need at places where I think they are needed, with a hierarchy that I think is appropriate --- Quote End --- Yep, me too. With that in mind, take a look at this DE0-nano SDRAM project and this BeMicro-CV DDR3 project. They demonstrate how you can create everything from scratch via Tcl scripts and source code. http://www.alteraforum.com/forum/showthread.php?t=45927 (see Post#2 attachment) http://www.alteraforum.com/forum/showthread.php?t=43992 (see Post#5 attachment) Cheers, Dave
