18 years agoI almost get the answer!
In SOPC Builder, My custom IP has two clock input. CLK0 CLK1 I use altpll IP and generate two clock: PLL.C0 = 80 MHz PLL.C1 = 100MHz then I connect PLL.C0 to CLK0; PLL.C1 to CLK1, then generate.... After full compilation in QuartusII 7.2, I open RTL View and find that both CLK0 & CLK1 connected to PLL.C1, and neither connected to PLL.C0. That's why I can't find timing report of PLL.C0. But Why both CLK0 & CLK1 connected to PLL.C1, and neither connected to PLL.C0?
