15 years ago
Why BSF files are skipped in .qar generation
I am looking to find out why BSF files don't make the .qar archive when a .qar archive is created from an existing project?
Let's say I have a project with 10 different BDF design files that represent hierarchical details of 10 instances of 10 different symbols. I generate code by pushing into all instances, run modelsim simulation, and everything works fine.
Next, I create a .qar file. Upon unpacking the qar file, I noticed that the BSF files are conspicuously missing, but I see instances of the BSF file in the project as before, and yet I don't see BSF files in the project directory. Also, I am still able to generate HDL and run modelsim simulation.
I tried all options under the project->archive pull down menu, but to no avail. The reason I need the BSF files to be a part of the archive (.qar) is to create an exact replica of all the existing files in the project and pass it around to group members that I work with. Note, this is not a huge issue, because the BSF symbol can always be created from the BDF by doing a symbol create and making sure that the instance of the latest created symbol is instantiated in the design. But when you are dealing with a design with a huge amount of BDF/BSF pairs, the effort can be mammoth.
The other interesting thing I noticed is that the missing BSF file(s) is mainly an artifact of blocks that underwent BDF->BSF symbol creation. If a block is created via the mega-funct generation approach, I see that the BSF file appears in the .qar file. Is there something I am missing ?
The other option I tried is to email the zip file containing the entire project and all the associated files, which works perfectly well. Of course I had to delete dB, incremental_dB simulation folders, else the zip file size becomes enormous.
    what version are you using, and are you seeing different behavior now than in the past?
    Thanks for your prompt response. I am using Quartus II 9.0 version. I have not re-pointed my tool in a long time. I just happened to notice the problem last week. Anyway, I am just curious to know why BSF files are not included in the archiving process.
