DWhit11
7 years agoWhy am I getting "clearbox.exe has stopped working" when I run the ALTMULT_COMPLEX Megawizard?
Running both Quartus 18.0 and 18.1 (both lite) on Windows 10 - when I start the wizard clearbox.exe popups up a stopped working. The wizard UI runs through but isn't generating the files correct...
Vicky1
7 years agoHi Dave,
Actually I tried with Q16.1, Q18.0 & Q18.1 Lite that too different-different machines but I haven`t come across the issue you are facing.
Could you please help me to check at your end with different machine?
I will also check in parallel with Q19.1 Lite, if possible you can also check with latest version.
thanks,
Vikas
