ddbug
6 years agoWhich file format is suitable for Passive Parallel Programming of Cyclone 10?
Which output file format do I need to create for Passive Parallel loading of Cyclone 10? No encryption, compression, device chaining etc. Just a sequence of bytes (octets) to send to he FPGA by (say)...
- 6 years ago
The answer: use RBF format. Just send all bytes as is, and add few dummy clock cycles after the last byte,
-- dd
ddbug
6 years agoThe answer: use RBF format. Just send all bytes as is, and add few dummy clock cycles after the last byte,
-- dd
