8 years agoWherer does Quartus put files?
I seem to be playing whack-a-mole With Quartus. I make a change and when I compile, Quartus will undo my change and find the error. I even did a search on the folder and found another .vhd file...
8 years agoHow are you adding files? and where are these files coming from? generated IP? Qsys?
I have never had a problem with files you added to a quartus project manually - it leaves them wherever they were. I also tend to generate Megawizard/IP catalog files into a known location and then add the generated files into the project manually. Then Quartus never makes a copy or messes with my file structre.
