8 years agoWherer does Quartus put files?
I seem to be playing whack-a-mole With Quartus. I make a change and when I compile, Quartus will undo my change and find the error. I even did a search on the folder and found another .vhd file...
8 years agoIt is clear where Quartus is putting the .sof and other output files. My issue is that Quartus makes two copies giving me three files. One each are located in submodules folders. That would be fine, however, when I get a compile error, I click on the error location and it opens one of the copies in a submodules folder instead of the file opened in Quartus.
Although the error description is so generic, it would appear to be a better solution to put a blinking cursor at the first stall point.
