12 years agoYes, "acl_quartus_report.txt" contains the kernel clock frequency. Is there any file report about whether the timing constraint of the kernel is satisfied at the given clock frequency?
--- Quote Start --- I went ahead and compiled a small kernel so that I can look at the output file set. I recommend using the file called "acl_quartus_report.txt" which will contain the hardware resources and kernel clock frequency. The kernel 1x clock is what the kernel logic (all the kernels in the .cl file) operate at in the hardware. --- Quote End ---
