BGrat
7 years agoWhere did the Memory Editor settings go? (Quartus 17.1)
When doing a MIF update, I get the following warning: Warning (113007): Byte addressed memory initialization file "armboot.hex" was read in the word-addressed format Not surprisingly, when reading ...
BGrat
7 years agoNow I'm getting this warning, even though I have no idea where this .hex file is used and it does not show up in the Analysis & Synthesis RAM report...
Warning (113006): Word addressed memory initialization file "pm_uc_ww49p5_main.hex" was read in the byte-addressed format
- RRomano0017 years ago
Contributor
HI, not sure this address your problem.
Tools memory content editor is not referred to files but to device thru JTAG.
To edit an Hex file you can use file -open select HEX-MIF then select file and edit.
Before to open edit as shown a panel require you about word size slecting number of bit:
after that cell editor pane appear on quartus editor space:
Not sure due offset byte /word can be 2 not 4 so you are reading 32 bit mode?
