JHaye4
7 years agoWhen using quartus_ipgenerate I get an error stating "Argument list too long" on Linux.
In the directory where my chiptop.qpf file is I'm trying to use this command specifically: "quartus_ipgenerate chiptop --generate_project_ip_files --synthesis=vhdl --clear_ip_generation_dirs". Howev...
JHaye4
7 years agoWhen I run the command with the wording order as you suggested it takes approximately 3 minutes and the only info that is printed to the terminal are the two lines in my original question, nothing else.
