gyuunyuu
Contributor
6 years agoWhen Qsys system is created, how is the order of conduit signals decided?
I have a single conduit on my Qsys component. This conduit contains a range of signals which are not are inter-related. However, in the RTL code related signals are bunched together.
When I goto th...
SyafieqS
5 years agoHi Hassan,
The order of the conduit signal is determined by order in you _hw.tcl generated by Qsys not rtl. The Qsys will generate you tcl file after you finish creating custom component. You can set the order from there (_hw.tcl) for signal order and see the in Qsys block/Inst Template changes.
