FGECE's avatar
FGECE
7 years ago
When I try to make and run University Program VWF, it gives this error :"ModelSim executable not found" .
As a solution, it says that: "To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used."
First I have searched and found that i should have “C:\altera\13.1\modelsim_ase\win32aloem\” this file direction and file in my computer but there is no such file and I have reinstalled the program. Still it has same problem.
What can I do for that problem? Thanks...
  • sstrell's avatar
    sstrell
    So what directory have you installed ModelSim-Altera edition? Point Quartus to that location (the win32aloem directory).
    #iwork4intel
      • russesho's avatar
        russesho
        If you installed it in :
        C:\altera\13.1_web
        you need to go to options => EDA Tool Options and under ModelSim-Altera enter:
        C:\altera\13.1_web\modelsim_ase\win32aloem
        Essentially you need to add \modelsim_ase\win32aloem to the install location.
  • Vicky1's avatar
    Vicky1
    May I know any update or shall I consider to be case closed?
    -Vicky
