12 years agoMy bad... all the elements of a struct must share the same type of assignment. My combination of continuous and procedural assignments above is what caused the initial state confusion. Structs aren't necessary for what I was trying to do, anyway. Here's a version that works in ModelSim and builds in Quartus:
interface my_interface;
logic some_byte;
logic increment_enable; //This is an input from another module
endinterface
module fpga_test(
input wire clk,
my_interface ports
//Create arrays used to work around the issue of not being able to access elements of a port array in loops
logic increment_enables ;
logic some_bytes ;
//Use generated assignments to make the local arrays proxies for the port array elements.
genvar n;
generate
for(n=0; n<4; n++) begin: port_assignments
assign ports.some_byte = some_bytes;
assign increment_enables = ports.increment_enable;
end
endgenerate
initial begin
for(int n=0; n<4; n++) some_bytes = '1;
end
function increment_now; //Check if any increment_enable lines are high
automatic logic result = 0;
for(int n=0; n<4; n++) result = result | increment_enables;
return result;
endfunction
function get_increment_index; //Get the index of the lowest active increment_enable
automatic logic result = '0;
for(int n=0; n<4; n++) begin
if(increment_enables) begin
result = n;
break;
end
end
return result;
endfunction
always_ff @(posedge clk) begin
//Check if any of the increment_enable lines are high. If one or more is high, only act based on the lowest index.
if(increment_now) some_bytes <= some_bytes + 1'd1;
end
endmodule Now that everything is working with loops, it should scale easily. This accomplishes what I was going for, so I have a workable solution now. Maybe someone else will find the code and issues useful.
