VCher6
7 years agoWhat means IC Fanout field
Hello! I ran in such problem: Can’t find in documentation what Fanout in Interconnect row means. In Cell row Fanout means fanout of output nets. But Fanout in IC row mysterious for me. I ran...
KennyT_altera
7 years agoIf you click correctly, you should be able to click on the bottom left signal to see the fanout connection.
Try not to select any signal in the time quest when you locate it to chip planner.
- VCher67 years ago
When I "Report Path in Chip Planner" and then double click on exact node in "Locate History" block, and click on "Generate Fanout Connections", I recieve Fan-out which located in "CELL" row below or above orange framed row, and NOT in "IC" row.
(Yes, I have counted for 200 arrows =)
