gyuunyuu
Contributor
5 years agoWhat is the limit on signals in signal tap II
The byte blaster cables have a data limit. Signal Tap requires that data be transmitted through the byte blaster on every single trigger event.
How do we know how much bandwidth signal tap is using...
- 5 years ago
Again, using a state-based trigger or other options I mentioned, you can capture data from multiple subsequent events before the logic analyzer stops, limited by the size of the buffer.
gyuunyuu
Contributor
5 years agoThis means there is a weakness since the logic will not look for another trigger event until the current data has been pushed out to the computer. This means that certain trigger conditions can get ignored by it if they occur too soon.
sstrell
5 years agoAgain, using a state-based trigger or other options I mentioned, you can capture data from multiple subsequent events before the logic analyzer stops, limited by the size of the buffer.
