gyuunyuu
Contributor
5 years agoWhat is the limit on signals in signal tap II
The byte blaster cables have a data limit. Signal Tap requires that data be transmitted through the byte blaster on every single trigger event.
How do we know how much bandwidth signal tap is using...
- 5 years ago
Again, using a state-based trigger or other options I mentioned, you can capture data from multiple subsequent events before the logic analyzer stops, limited by the size of the buffer.
