AHail
7 years agoWhat is the best way to preserve an FPGA project (with a released build and programming file), so that Timing Analysis can be done later, on that particular build?
GuaBin_N_Intel
Contributor
7 years agoYou can preserve the logic placement and routing in particular module or block through Design Partition https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-block-based-design.pdf. Normally, we do this when code freeze or it's no longer changed in RTL.
