BGrat
7 years agoWhat is pm_uc_ww49p5_main.hex?
After changing the Memory Editor to read byte-addresses instead of word-addresses I am getting the warning Warning (113006): Word addressed memory initialization file "pm_uc_ww49p5_main.hex" was re...
FawazJ_Altera
7 years agoHello,
Are you trying to read the memory content of on chip memory on FPGA in Quartus?
Or is it the memory editor in Eclipse?
The on chip memory is initialized with a default hex file, unless the developer would use a specified hex instead of the default one, or disable the default initialization file.
- BGrat7 years ago
I am not trying to read the content of the on-chip memory--only trying to understand the boot process at the lowest level. If it is possible to edit or modify the pre-loader, that would be interesting to me--even if we most likely would not do that.
Brian
