Nobody knows?
First of all, not everyone browses the forums at all times, so you may need to wait a while for a response.
Trigger conditions are the conditions required to trigger a download of captured signals to the PC. ALL conditions must be met simultaneously to trigger this. All signals are constantly recorded, so the triggers will download all signals. This allows you to check the state of all signals when trigger occurs. - Altera_Forum
Thanks very much, Tricky. Sorry, I am just a little hurried in this question.
I am still a little confused. Does that mean without trigger, although all the signals are recorded, I still can't watch them since they are not download to PC? If I set the trigger condition as don't care, what will happen? Will the signals will be download to PC all the time since the condition is always met? Thanks again! - Altera_Forum
If you dont set a trigger (eg, all signals set to dont care) it will just download whatever is in the buffer right now. THere is also a "continuous button" that will keep downloading every time a trigger occurs. With dont cares set here, it just continuously downloads (but its not real time, as it takes time to reset).
Thanks very much, Tricky!
