8 years agoWhat is Altera equivalent of Xilinx`s IBUF?
Hi, Could someone tell if there is similar or equivalent in Altera of Xilinx`s IBUF? Thanks
8 years ago --- Quote Start --- Hi, Altera also has IO buffers , these are called ALT_INBUF. Example :
module io_primitives (data_in, data_out);
input data_in;
wire internal_sig;
output data_out;
alt_inbuf my_inbuf (.i(data_in), .o(internal_sig));
defparam my_inbuf.io_standard="1.8 V HSTL Class I";
assign data_out = !internal_sig;
endmodule
For more information refer https://www.altera.com/en_us/pdfs/literature/ug/ug_low_level.pdf --- Quote End --- How to customize the ALT_INBUF IP core. For example 4-bit counter 4-bit counter output , how i need to connect to outbuff-diff for 4 bits.
