What can cause a clock signal being distributed to a DFF chain to have several delta cycles delay on one DFF?
- FHall17 years ago
How i fixed it: I deleted that part of the .bdf and redrew it using exactly the same DFF type. Why this worked i don't understand, which is what I'm trying to figure out.
I just compared the .vho files, specifically the port mapping of the clock inputs of the DFFs in question and noticed the following:
inst2: clk => \CLOCK_1600Hz~inputclkctrl_outclk\
inst41: clk => \CLOCK_1600Hz~inputclkctrl_outclk\
inst6: clk => \CLOCK_1600Hz~input_o\
inst44: clk => \CLOCK_1600Hz~inputclkctrl_outclk\
inst11: clk => \CLOCK_1600Hz~inputclkctrl_outclk\
inst45: clk => \CLOCK_1600Hz~inputclkctrl_outclk\
I paired the "equivalent" DFFs to show that the DFF that had a clock signal that had some delta was actually mapped to a different signal than the others. I'll include the parts in the .vho that show where these two signals come from. I don't understand why this happens though.
\CLOCK_1600Hz~input\ : fiftyfivenm_io_ibuf
-- pragma translate_off
GENERIC MAP (
bus_hold => "false",
listen_to_nsleep_signal => "false",
simulate_z_as => "z")
-- pragma translate_on
PORT MAP (
i => ww_CLOCK_1600Hz,
o => \CLOCK_1600Hz~input_o\);
\CLOCK_1600Hz~inputclkctrl\ : fiftyfivenm_clkctrl
GENERIC MAP (
clock_type => "global clock",
ena_register_mode => "none")
PORT MAP (
inclk => \CLOCK_1600Hz~inputclkctrl_INCLK_bus\,
devclrn => ww_devclrn,
devpor => ww_devpor,
outclk => \CLOCK_1600Hz~inputclkctrl_outclk\);
Thanks!
Felix
