9 years agoWeird SignalTap behaviour
Trying to solve a mystery, but after several days ran out of thoughts :( Needed to connect to SignalTap around 100 (probably, a bit less) signals, and at some moment got very strange picture (...
9 years ago --- Quote Start --- Defining the 210 MHz clock correctly in it's own clock group should assure that the signal tap logic is working correctly inside, or if not possible with the given clock report a timing violation. --- Quote End --- Have very limited experience with time analyzing, not sure how to define a clock for SignalTap correctly :(
