9 years agoWeird SignalTap behaviour
Trying to solve a mystery, but after several days ran out of thoughts :( Needed to connect to SignalTap around 100 (probably, a bit less) signals, and at some moment got very strange picture (...
9 years ago --- Quote Start --- This can happen under circumstances for a wrongly constrained design that tries to fix timing violation in one place and newly generates others instead --- Quote End --- Actually, I don't have any constrains at this part of the project... It's the biggest problem for me - everything looks VERY straightforward, so I ran out of ideas at the moment :( But I will check if the PLL locked (even if I THINK it's not a reason) - thanks for the suggestion ! - update - as expected, the PLL is reliably locked...
