9 years agoWeird SignalTap behaviour
Trying to solve a mystery, but after several days ran out of thoughts :( Needed to connect to SignalTap around 100 (probably, a bit less) signals, and at some moment got very strange picture (...
9 years agoThe purpose of signaltap is to sample a signal on the provided signaltap clock.you should sample signal on same clock that you are planning in the design otherwise clock ratio and timing gives weird results.
