Well I fixed that problem somehow, but I have another one. My write signal is working but if I don't put in the output so that I can see my write enable signal it misses the first nib. If I just put in the output signal, it gets the first nib. I don't see why the presence or absence of a test signal should influence the result.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
--This version starts storing frames at address 0, so you can store a bunch of frames and then send them all out at once
entity framestore is
port
clk,reset : in std_logic;
input: in std_logic_vector(3 downto 0); -- the input ethernet frame
valid: in std_logic; --valid signal that comes with input
readEN: in std_logic; --high when we want to read from memory
wrenout: out std_logic;
output : out std_logic_vector(3 downto 0) --output, has value if we're reading
end framestore;
architecture structure of framestore is
signal holdout: std_logic_vector(3 downto 0);
signal address: std_logic_vector(14 downto 0);
signal next_address: std_logic_vector(14 downto 0);
signal regRead: std_logic;
signal regValid: std_logic;
signal readEN_RE: boolean;
signal valid_FE: boolean;
signal wrenframe: std_logic;
signal counter: integer range 0 to 23;
component ram4bits is
PORT
address : IN STD_LOGIC_VECTOR (14 DOWNTO 0);
clock : IN STD_LOGIC := '1';
data : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
wren : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (3 DOWNTO 0)
end component;
begin
process(clk,reset,valid,readEN)
begin
if(reset = '1') then
next_address <= "000000000000000";
regRead <= '0';
regValid <= '0';
elsif(clk'event and clk = '1') then
regRead <= readEN;
regValid <= valid;
if(readEN_RE) then
elsif(valid = '1' or readEN = '1') then
next_address <= address + '1';
counter <= 0;
elsif(valid_FE or counter > 0) then
counter <= counter + 1;
end if;
if((valid = '0' and readEN = '0' and counter > 0) or valid_FE) then
end if;
if(counter = 25) then
counter <= 0;
end if;
end if;
end process;
store: ram4bits port map(address,clk,input,wrenframe,holdout);
readEN_RE <= regRead = '0' AND readEN = '1';
valid_FE <= regValid = '1' AND valid = '0';
wrenframe <= '1' when (valid = '1' or counter > 0 or valid_FE) else '0';
output <= holdout when readEN = '1' else "0000";
address <= next_address;
wrenout <= wrenframe; --this is the line that makes things work if it's present
end structure;
