MMomc
6 years agoWe just installed 3 purchased copies of Quartus Prime on a lab network. The GUI opens and compiles properly but the "Messages" window does not show anything such as syntax errors, warnings, etc. Is it possible that our installer mis-set a default option?
I can run the same source code on our corporate enterprise Linux network and see the routine errors and messages.
KennyT_altera
6 years agoDid you tick anything at the top of the Processing menu? Can you attached a screenshot for us to have a look?
MMomc
6 years agoNo screen shots available due to proprietary net. We also pulled down the Compilation Report and look at Messages tab and it looks like the GUI tab which is empty.
We are running 2019.4 on Linux and 2019.3 on Windows and the Windows Messages are fine and normal. We will be opening a support case.
