8 years agowaveform simulation error
Hi All, I am completely new to this forum and to the Quartus II software and am seeking a bit of guidance. I make a program of prime number detector in the vhdl file. here is the code
lib...
8 years agoIf you've installed Modelsim Altera/Intel edition, then to enable the tool, you need to specify the installation path in the Quartus tool. To do so, do the following.
1. Launch Quartus tool 2. From the menu choose Tools --> Options. 3. In this Options window, look at the list in the left pane. Select "EDA Tool Options" from the list. 4. Now, in the right pane, you will see a list of tools with blank text boxes. Choose the box with [...] next to ModelSim. 5. Browse to the location of Modelsim installation and point to the Win32 folder.. for example .. C:\intelFPGA\17.1\modelsim_ase\win32aloem . 6. Click the "Select Folder' button and close the windows. Now, you can launch ModelSim from the Quartus menu for Simulations. Provided you have a valid license for it.
