12 years agoHave your provided path of Modelsim as suggested in your image?
You can use modelsim standalone as well.No need for the quartus to run the Modelsim. You can create project in Modelsim and add the source file and test bench file to the project.Compile and simulate. You can find tutorial to simulate the design in modelsim from the Help once you open the Modelsim.
