12 years agosir i have ver 13.1 and also installed model sim but still the simulation is not running plz let me know which settings i do for making waveform using modelsim simulator. thanks in advance.
--- Quote Start --- Altera has removed the support for simulator after Quartus v 9.1 so you won't be able to use Quartus Simulator in newer version. As you can see from the message you can use Altera-Modelsim.You can download it from the altera website. --- Quote End ---
