12 years ago --- Quote Start --- I am able to simulate the same design which you have attached with Quartus v9.0 without any error.I have attached image of waveform. --- Quote End --- Many thanks for your response. I will double check what version we are running, but i believe it is also 9. Are you running an updated version of 9 perhaps? Just for clarity, how exactly did you get the figure in the document? Did you just simply click on 'Start Simulation' under the processing menu? The figure is what I would also expect to see from the simulation.
