17 years agowarning with on chip memory data items width
hello, I use quartus II 8.0 and statixII gx ep2s60GX. I made a modification in my current design (which works well) in .vhd file. Now I've got this warning from onchip memory. ...
9 years agoHi,
I'm having similar warnings. My hex file is being generated by NIOS ii SBT for eclipse. From this link (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03252015_881.html) altera shows the solution. "Description You may see this warning when using memory initialization files generated by the mem_init make target in the makefile generated by the Nios® II Embedded Design Suite (EDS). The reason for this warning is that the Quartus® II software expects the record length within .hex files to match the data port width of the memory that is initialized. Workaround/Fix To change the generated .hex files to have a record length that matches the memory data port width, modify the mem_init.mk file within the BSP directory: Find the ELF_TO_HEX_CMD_NO_BOOTLOADER command add the following switch: --record=/8 This problem is scheduled to be resolved in a future release of the Quartus II software." Based on the solution above, I'm not sure where to add the switch that was mentioned above. The boot loader command I found on my mem_init.mk file is below "ELF_TO_HEX_CMD_NO_BOOTLOADER = $(ELF2HEX) $< $(mem_start_address) $(mem_end_address) --width=$(mem_hex_width) $(mem_endianness) --create-lanes=$(mem_create_lanes) $(elf2hex_extra_args) $@" Question is where to add the --record=/8?
