18 years agoHi Brad!
Ok, I found the problem that was causing the "removed fan-in" error message. In another of the vhdl modules in the project I was simultaneously sending a register read and a register write signal. Once I corrected the timing of the register read signal, the error message cleared. Thanks again for your help, I really appreciated having someone to discuss this with! :)
