18 years agoHi Brad,
Right up front, I'd better say, again, thank you for helping me. I really do appreciate it! So, let me tell you what I found! It turns out that the compiler warning that I get (removed fan in from always disabled... etc) when I try to put that register module in my design is being caused by the read enable(not) signal (which is supposed to put the register contents on to the bus). If I replace the register select line that I have the module connected to with one from a different part of the circuit, the compiler error goes away. So, this makes me suspect that there is something wrong with another module that I'm using that routes a signal read(not) on to one of 64 output lines based on an 8 bit address. I'll include the code below and if you see anything suspicious about it please let me know. The crazy part of this whole exercise is that when I model this code using modelsim everything works exactly like I expect it to! entity registerRdWrSelect is port ( nRdIn : in std_logic; nWrIn : in std_logic; Addr : in std_logic_vector(7 downto 0); nRd : out std_logic_vector(63 downto 0); nWr : out std_logic_vector(63 downto 0) ); end registerRdWrSelect; architecture registerRdWrSelect_arch of registerRdWrSelect is begin -- registerRdWrSelect_arch readEnableNotSignalDemux:process(Addr, nRdIn) begin nRd <= (others => '1'); if nRdIn = '0' then nRd(to_integer(unsigned(Addr))) <= '0'; end if; end process; writeEnableNotSignalDemux:process(Addr, nWrIn) begin nWr <= (others => '1'); if nWrIn = '0' then nWr(to_integer(unsigned(Addr))) <= '0'; end if; end process; end registerRdWrSelect_arch;
