12 years agoThe tool includes the pin capacitance of the package, but not the external device. You can see the difference in the package pin capacitance in the delays calculated for VREF pins versus normal I/O pins.
Quartus does not know what you have connected the FPGA pins to, so its up to you to provide that information. Here's an example ... http://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.zip Cheers, Dave
