8 years agoWarning Message: Time Limited megafunction while programming the FPGA
While programming the CYCLONE V FPGA, that pop-up window is opening. Please anyone suggest why that warning message.
Please find the attachment.5 Replies
This warning indicates that you are using some licensed IP core. Which version of NIOS you are using? NIOS/e or NIOS/f ? - Altera_Forum
I am using NIOS/f version. Will affect my design process. Because i am unable to find elf file.
--- Quote Start --- I am using NIOS/f version. Will affect my design process. Because i am unable to find elf file. --- Quote End --- NIOS/f - is not free, you need to buy license for this version. - Altera_Forum
--- Quote Start --- NIOS/f - is not free, you need to buy license for this version. --- Quote End --- Can i use this NIOS/e instead of NIOS/F ? - Altera_Forum
--- Quote Start --- Can i use this NIOS/e instead of NIOS/F ? --- Quote End --- Yes, you can but take in mind that NIOS/e does not have some features as NIOS/f such as interrupts, hardware multiply/divide ect.
