15 years agoWarning: Converted elements in bus name "" using legacy naming rules.
I have a module symbol on my top level block diagram/schematic connected to a few input and output buses. When I compile I always get the the warning "converted elements in bus ... name using legacy...
8 years agoHello
I based a very simple BDF design on an automatically generated project by the Terrassic system builder. The connections to the LEDR[x] and KEY[0] were not compiled correctly until I followed the setting above. In Q17 the settings have moved to: Assignments / Settings / Compiler Setting / Advanced Settings (Synthesis) [button] / Block Design Naming { => set this to Quartus II} Best Regards, John.
