Warning: Can't generate programming files because you are currently using the Quartus II software in
As an FYI, I have a TerAsic DE1 board with the CycloneII device and I use Quartus Web 13.0sp1 to compile code for the board.
It works just fine. I have used it on XP and Win7 and now Win10; have not tried Win11.
So 13.0sp1 is the way to go forward.
Hi.
Do this version need any license?
Thank you.
S_Dyn.
- _AK6DN_1 year ago
No, the web version of Quartus 13.0sp1 does not require a license. Just install and run. It supports the DE1 board directly.
- S_Dyn1 year ago
Hi.
I get the message when I open the QII.
Would I face the same issue where the .sof file is not generated after compilation because of the web version?
Thank you.
S_Dyn.- _AK6DN_1 year ago
Select the second option "Run the Quartus II software" when you install.
You don't need or want the subscription version which requires a paid license, and
I am assuming you are not using any purchased IP files so the third option does not apply.Once the web version is installed, it won't ask you again about licensing.
