S_Dyn
1 year agoWarning: Can't generate programming files because you are currently using the Quartus II software in
Hello. I am currently using Quartus II ver 7 Web Edition. May I know what does this error means? Thank you. S_Dyn
FvM
1 year agoHi,
you are confusing versions. 13.0.1 is 13.0sp1, you are showing device support info of 13.1
You minimally need two installation files from "Individual Files" tab, QuartusSetupWeb-13.0.1.232.exe 1.5 GB and cyclone_web-13.0.1.232.qdz, 569 MB.
Frank
- _AK6DN_1 year ago
As an FYI, I have a TerAsic DE1 board with the CycloneII device and I use Quartus Web 13.0sp1 to compile code for the board.
It works just fine. I have used it on XP and Win7 and now Win10; have not tried Win11.
So 13.0sp1 is the way to go forward.
- S_Dyn1 year ago
Hi Frank.
I really appreciate your advise.
Ill try to install now.
Thank you.S_Dyn.
